Configuring GIS Subsystem
All address information for online tracking and reports is taken from Gurtam Maps. The formats of the map files for Gurtam Maps are specific vector graphics files that contain a map of a specific area. This format is not editable and is intended for use in the map server of Gurtam Maps.
Gurtam Maps are created from vector maps in different formats such as MP, MapInfo, ESRI Shape, OSM (OpenStreetMap), or KML. Note that a source map should be in the WGS-84 coordinate projection in grades.
Vector maps in the closed Gurtam Maps format allow ADF-based programs to render map images, search for named elements, use geocoding, including reverse geocoding.
Limited access is possible with the maps. It means that the detailed map of some town or region can be available only to users with certain billing plan. To add such maps, forward a request to support@s-watcher.com
Questions and answers
How can I upload a map to Gurtam Maps?
To add a new map, send your request to support@s-watcher.com. Attach a vector map in one of the supported formats (MP, MapInfo, ESRI Shape, OSM, or KML) to your email and give us a link to download the map. The data must be in the WGS 84 coordinate system.
I have a list of addresses in an XLS table. Can you add them to Gurtam Maps?
A CSV or XLSX table can be used to upload addresses to Gurtam Maps. Such table should contain the following columns: house number, street, city/town, region (optional), X and Y coordinates in WGS-84 in decimal degrees (for example, 64.78236, -17.20469).
Can I use data from AutoCAD for import to Gurtam Maps?
Gurtam Maps do not support the DWG format, but AutoCAD allows you to export data to other formats supported for import (MP, MapInfo, ESRI Shape, OSM, KML). Make sure that WGS-84 is set for the data.
Can I upload a satellite image to Wialon?
To upload satellite images or other raster data to Wialon, you should use third-party cartographic services, for example, Mapbox or ArcGIS.
Can I make a map available only to one client?
You can limit the access to custom maps with a  billing plan . If you want a map to be available only to one client, create a separate billing plan, assign it to the client’s account, and specify the name of this billing plan in your request to support@s-watcher.com . The map will be available only to the users that use accounts with the created billing plan. It will not be available to other Wialon users.
Incorrect address information is displayed in reports, notifications, or the search tool. What can I do?
Please, send your request to support@s-watcher.com  indicating the coordinates of the place and the correct address.
Gurtam Maps do not display addresses in my region. What can I do?
In this case, it is necessary to upload a more detailed map to Gurtam Maps. If you have a map of your region in one of the supported formats (MapInfo, ESRI Shape, OSM, KML), you can send it to us for adding to Gurtam Maps. We can also use the data of open sources, for example, OpenStreetMap. You can add the missing information to OpenStreetMap and then email us to support@s-watcher.com. We will try to upload the data to Gurtam Maps.
What can I do in case of an error, incorrect address, or no address in Google, HERE, and other maps?
Consult the service directly. We can only connect third-party cartographic services and are not responsible for their contents.
Conversion table: polyline
.MPOSMGurtam Maps
CodeKeyValueKeys
Key_
values
Type
GM
type
Data
level
(0-2)
CommentImageIcon
0x0001
highway
motorway
PL
A restricted access major divided highway, normally with 2 or more running lanes plus emergency hard shoulder. Equivalent to the Freeway, Autobahn, etc.
0-4
5-9
10-12
highway
motorway_link
PL
The link roads (sliproads/ramps) leading to/from a motorway from/to a motorway or lower class highway. Normally with the same motorway restrictions.
0-4
5-7
0x0002
highway
trunk
PL
Important roads that are not motorways. Typically maintained by the central, not local government. Need not necessarily be a divided highway.
0-4
5-9
10-12
highway
trunk_link
PL
The link roads (sliproads/ramps) leading to/from a trunk road from/to a trunk road or lower class highway.
0-4
5-7
0x0003
highway
primary
PL
Roads generally linking larger towns.
0-5
6-12
highway
primary_link
PL
The link roads (sliproads/ramps) leading to/from a primary road from/to a primary road or lower class highway.
0-5
6-7
0x0004
highway
secondary
PL
Roads generally linking smaller towns and villages.
0-5
6-9
highway
secondary_link
PL
The link roads (sliproads/ramps) leading to/from a secondary road from/to a secondary road or lower class highway.
0-5
6-7
0x0000
highway
tertiary
PL
Minor roads.
0-5
6-8
highway
tertiary_link
PL
The link roads (sliproads/ramps) leading to/from a tertiary road from/to other minor roads.
0-5
0x000a
highway
unclassified
PL
Unclassified roads typically form the lowest form of the interconnecting grid network.
0-3
4-7
0x0042
highway
unsurfaced
PL
Unpaved roads.
0-3
4-7
highway
track
PL
Roads for agricultural use, gravel roads in the forest etc., usually unpaved/unsealed but may occasionally apply to paved tracks as well.
0x0005
highway
residential
PL
Roads accessing or around residential areas but which are not a classified or unclassified highway. Streets.
0-4
5-7
0x0006
0x000b
0x0008
0x0009
0x0049
highway
living_street
PL
A street where pedestrians have priority over cars, children can play on the street, the maximum speed is low. Sometimes called Home Zone.
0-2
3-5
0x0007
highway
service
PL
Generally for access to a building, motorway service station, beach, campsite, industrial estate, business park, etc. This is also commonly used for access to parking and trash collection.
0-2
3-5
highway
bridleway
PL
Roads for horses, cartage.
highway
cycleway
PL
Cycleways for bicycles.
cycleway
lane
PL
A lane is a route for bicycles that lies within the roadway.
cycleway
track
PL
A route for bicycles that is separate from the road.
highway
footway
PL
Footpaths for pedestrians, e.g., walking tracks and gravel paths.
0x0048
0x0016
highway
pedestrian
PL
For roads used mainly/exclusively for pedestrians/shopping areas. Also for tagging squares and plazas.
highway
bus_guideway
PL
A busway where the vehicle guided by the way (though not a railway) and is not suitable for other traffic.
0-3
4-7
junction
roundabout
PL
Circle movement.
0-3
4-6
0x0014
railway
rail
PL
Full-sized passenger or freight trains in the standard gauge for the country or state.
railway
tram
PL
One or two carriage rail vehicles, usually sharing the motor road for trams.
0x001f
waterway
river
PL
For narrow rivers which will be rendered as a line.
0x0018
waterway
canal
PL
An artificial open waterway used for transportation, waterpower, or irrigation.
0x0026
waterway
stream
PL
A naturally-formed waterway that is too thin to be classed as a river. An active, able-bodied person should be able to jump over it if trees along it are not too thick.
0x0044
waterway
drain
PL
An artificial waterway for carrying storm water or industrial discharge.
waterway
weir
PL
A barrier built across a river, sometimes to divert water for industrial purposes. Water can still flow over the top.
waterway
dam
PL
A wall built across a river or stream to impound the water. A dam normally does not have water flowing over the top of it.
aeroway
runway
PL
A strip of land kept clear and set aside for aeroplanes to take off from and land on.
0x0045
0x001d
boundary
administrative
admin_level
PL
191
State, county, local council.
0x001c
PL
192
Region boundary.
0x001e
boundary
administrative
admin_level
border_type
nation
PL
193
National boundary.
Conversion table: POI
.MP.OSMGurtam Maps
CodeKeyValueType
GM
type
Data
level
(02)
CommentImageIcon
0xf201
highway
traffic_signals
POI
Lights that control the traffic.
0xf002
0x2f08
0x2f17
0xf001
0xf003
0xf004
highway
bus_stop
POI
A small bus stop.
highway
metro
POI
500
Metro.
highway
tram
POI
501
A tram stop.
0x5900
0x5901
highway
airport
POI
503
Airport.
0x2f03
highway
services
POI
A service station to get food and eat something, often found at motorways.
0xf007
railway
station
POI
A railway station.
0x4600
amenity
pub
POI
A place selling beer and other alcoholic drinks; may also provide food or accommodation.
0x2d02
0x2d00
amenity
nightclub
POI
A nightclub.
0x2a0e
amenity
cafe
POI
A cafe.
0x4500
amenity
restaurant
POI
A restaurant.
0x2a0d
amenity
fast_food
POI
An area with several different restaurant food counters and a shared eating area. Commonly found in malls, airports, etc.
0x2f0b
amenity
parking
POI
Car park or a parking.
0x2f02
amenity
car_rental
POI
A place to rent a car.
amenity
taxi
POI
A place where taxis wait for passengers.
0x2f01
0x4400
amenity
fuel
POI
Petrol station, gas station, marine fuel, etc.
0x2e05
amenity
pharmacy
POI
A pharmacy.
amenity
hospital
POI
A hospital.
0xf001
amenity
bus_station
POI
Bus station.
0x2f06
amenity
bank
POI
A bank.
amenity
bureau_de_change
POI
Currency exchange, a place to change foreign banknotes and traveller's cheques.
amenity
atm
POI
An ATM or cashpoint.
0x2b00
0x2b01
0x2b02
tourism
hotel
POI
A hotel, a motel, a guest house
tourism
hostel
POI
A hostel.
0x0100
POI
302
Capital.
0x0200
POI
A megalopolis over 5 million people.
0x0300
0x0400
place
city
POI
A city of 1-5 million people (MP).
A city over 100 thousand people (OSM).
0x0500
0x0600
0x0700
0x0800
0x0900
0x0a00
0x0006
0x0004
place
town
POI
A town from 10 to 100 thousand people.
0x0b00
0x0c00
0x0d00
0x0e00
0x0f00
0x1000
0x1100
0x0010
place
village_greenhamlet
POI
A village below 10 thousand people.
0x640a
POI
Captions.
place
continent
POI
195
A continent.
0x6602
place
state
POI
196
A state.
0x1e00
place
region
POI
197
A region.
0x1f00
place
country
POI
198
A country, area.
Conversion table: polygon
.MP.OSMGurtam Maps
CodeKeyValueType
GM
type
Data
level
(0-2)
CommentImageIcon
0x0047
0x003b
0x0045
0x0049
0x0040
0x0041
waterway
riverbank
PG
130
Used for large rivers, to define an area between the opposite riverbanks.
divided
by size
natural
water
PG
131
Lakes, water bodies, etc.
divided
by size
landuse
reservoir
PG
131
An artificial reservoir.
0x0028
PG
132
Sea, the ocean.
waterway
riverbank
PG
133
A large river.
leisure
park
PG
140
A park, open green area for recreation.
0x004e
0x004f
0x008e
0x0086
0x0087
0x0088
leisure
garden
PG
141
A garden.
0x006d
amenity
townhall
PG
145-146
A town hall building (mayor's office), administrative building.
0-2
0x001a
landuse
grave_vard
PG
147
A graveyard, a cemetery.
0x000a
amenity
school
PG
148
A school.
amenity
university
PG
148
A university.
amenity
college
PG
148
A college.
0x3002
amenity
hospital
PG
149
A hospital.
shop
building
supermarket
PG
151
A supermarket.
0-2
tourism
camp_site
PG
153
0
Camping, a place where you can pitch a tent.
tourism
caravan_site
PG
153
0
A place where you can park a caravan overnight or for longer periods.
tourism
picnic_site
PG
154
0
A place where you can have an outdoor picnic. May have facilities such as tables and benches.
tourism
theme_park
PG
155
A theme park, amusement park.
tourism
attraction
PG
156
0
A general tourism attraction.
tourism
zoo
PG
157
A zoo.
tourism
artwork
PG
158
A tag for public pieces of art.
historic
archaelogical_site
PG
159
0
Archaeological museum.
0x0050
0x0081
0x0082
0x0083
0x0084
0x0085
0x0052
0x008f
0x0090
0x0091
landuse
forest
PG
165
Managed forest or woodland plantation.
0x0001
0x0002
0x0003
landuse
residential
PG
166
Predominantly houses or apartment buildings.
0-3
4-7
landuse
retail
PG
167
Predominantly shops.
0-3
4-7
landuse
commercial
PG
168
Predominantly office buildings, business parks, etc.
0-3
4-7
0x000c
landuse
industrial
PG
169
Predominantly workshops, factories, warehouses.
0-3
4-7
0x0006
PG
169
0
Garages, vehicle sheds.
0-3
4-7
landuse
brownfield
PG
170
A district to be developed, an empty area.
landuse
greenfield
PG
170
Describes land scheduled for new development where there have been no buildings before.
landuse
railway
PG
171
Area for railway use, generally off-limits to the general public.
landuse
construction
PG
172
Something under construction.
0x0004
landuse
military
PG
173
For land areas owned/used by the military for whatever purpose.
landuse
airport
PG
401
Airport area.
0x0014
0x000d
0x0015
0x0016
0x0017
0x001e
0x001f
0x0020
0x0098
natural
wood
PG
184
Natural woodland (trees). Only for completely unmanaged/wild areas.
0x0051
0x0096
0x008b
natural
marsh
PG
185
Low poorly drained land that is sometimes flooded and often lies at the edge of lakes, streams, etc.
0x0018
sport
golf
PG
194
Golf course, football, stadium.
building
palace
PG
207
A palace.
0-2
building
postoffice
PG
208
A post office.
0-2
building
restaurant
PG
209
A restaurant.
0-2
0x006f
0x006f
amenity
public_building
PG
210
Public building.
0-2
0x0013
0x006c
building
yes
PG
210
General tag for buildings.
0-2
denomination
baptist
catholic
christian
evangelical
lutheran
roman_catholic
PG
211
0
A church.
0-2
0x9999
surface
PG
212
Bottom surface.
Gurtam Maps scale
Scale (km)
Scale (m)
Data level
Zoom level
Value
0,02
-1
2000
0,05
0
5000
0,1
100
0
0,15
150
0
0,2
200
0
0,5
500
100
100000
150
150000
200
200000
500
500000
