Tracking is carried out with the help of GPS and GLONASS devices as well as special software with similar features.
Configuring hardware
Copied!
The data from the devices should be sent to the server of Wialon. The frequency of data collection and sending as well as the parameters contained inside and overall correctness depend on how the device is configured. A device can be configured remotely or via a special configuration program if it is connected to a computer. It is specified in the manual provided with the device (the manual can be provided by the seller/manufacturer of the device).
Required settings for the equipment are the IP address and port that correspond to the specific device model.
When you select the device type, Wialon automatically detects the appropriate server IP address and hardware port. This information is displayed on the General tab of the unit properties.
The port is also specified on our website in the Hardware section. Find your device, click on it, and consult the Information tab for the port number.
Configuring Wialon
Copied!
If the device is set up properly and sends data to Wialon, to see it on the map, create a unit for it in the system. Upon unit creation pay attention to the required parameters:
name (any custom text),
device type (choose from the dropdown list or enter from the keyboard),
unique ID (device identification number).
The access password should be specified only if a device additionally encrypts the transmitted data.
Questions and answers
Copied!
How does the monitoring system work?
Copied!
The AVL hardware installed in a vehicle figures out the location of that vehicle with help of satellites, gathers data from various accessories and sensors and transmits the data through a cellular or satellite network to Wialon data center. This data can be interpreted to monitor in the Wialon web interface the whereabouts and other parameters of a vehicle in real time.
I haven’t found my device in the list of supported hardware in Wialon. What should I do?
Copied!
We’re ready to support a new device by customer’s request. All you need to do is to email us at hw@s-watcher.com. Please specify the following information in your email if possible:
Share your plans on project where you’re going to use this device;
Specify device model name and the manufacturer;
If you’re in contact with the manufacturer and you have an opportunity to request the device communication protocol, this will speed up the integration process a lot.
In case you don’t have the information mentioned above, don’t worry – we will contact the manufacturer ourselves and try to get whatever is required for integration.
I want to use LoraWan, Sigfox or other similar devices with Wialon. What should I do?
Copied!
The integration of LoraWan, Sigfox and other similar devices is the same as for any GSM hardware. If the device is not integrated yet, kindly contact us at hw@s-watcher.com.
I have found a device which interests me at s-watcher.com. How can I buy it?
Copied!
At Gurtam we do not sell any hardware devices. We’re the software developer only. Nevertheless, we’re trying to inform our customers about various hardware compatible with Wialon platform.
Therefore to get the device you’re interested in, please contact the manufacturer or your local supplier.
I don’t want to buy GPS hardware, but I want to use Wialon. What should I do?
Copied!
Your option is the WiaTag application – our proprietary software tracker. The application serves for basic tracking and efficient mobile workforce management.
WiaTag is absolutely free to download and install on iOS/Android devices.
I’ve designed my own GPS device. Which communication protocol should I implement?
Copied!
We recommend you to use Wialon IPS protocol. Wialon IPS communication protocol was developed by Gurtam for personal and vehicle GPS/GLONASS trackers, which send data to the satellite monitoring system server over TCP.
Wialon IPS protocol is freely distributed under GNU FDL and can be used by manufacturers of GPS and GLONASS equipment as the main protocol for data transmission between GPS/GLONASS trackers and communication server of the satellite monitoring system.
Which tracker works best with Wialon?
Copied!
Our goal is to support full trackers functionality in Wialon. We remain hardware agnostic company and do not distinguish any manufacturer leaving the choice to our customers. When choosing hardware you may refer to Gurtam rating of manufacturers or decide on any other device even if it is not integrated with Wialon yet.
I want to use some sensors with my tracker. Should they also be integrated with Wialon?
Copied!
In most cases, there is no need to integrate additional hardware with the platform since they work in conjunction with a GPS tracker. Therefore if the tracker is integrated with Wialon, you can connect various sensors to it.
In case when a sensor has its own GPS module or works through transparent channel, integration might be needed and we will list it as a separate device type in Wialon.
I don’t know my unit ID. What should I do?
Copied!
To check device unit ID, please use id.wialon.net service.
Point your device to IP 193.193.165.167, specify device port (you may check your device port here).
When the device connects to the server, there will appear its unique ID in the table of id.wialon.net service.
Save this unique ID in unit properties. Then redirect the GPS tracker to send data to Wialon.
How can I set up a tracker?
Copied!
First, please learn the device user manual provided by the manufacturer or supplier. If you still have difficulties with device configuration, email us at hw@s-watcher.com and we’ll do our best to assist you.
Which time zone should I set for my tracker?
Copied!
Though it is common to set up local time zone on GPS devices, it is not recommended, as Wialon works with data in UTC+0h time zone only. This is a mandatory requirement for correct data display in the system. So please reset time zone to UTC+0h in your device. Whereas, local time zone should be set in your Wialon account.
Yet there is an exception from the rule – GPS watch. In this case, you should set a local time zone in the device. When integrating such device type we allow for specifying local time zone in unit properties, after that Wialon will automatically adjust it to UTC+0h.
Seems like I set everything correctly, but the device doesn’t show online. What’s wrong?
Copied!
Make sure that the balance of the SIM card is positive and the PIN code is disabled.
Check your APN, IP and port settings as well as unique unit ID in unit properties in your Wialon account. Make sure there are no extra spaces, dots, etc.
Check that the device ‘sees’ the satellites. For instance, if the device is in the office, set the GPS antenna of the tracker outside the window. If the antenna is built into the device case, place it on the sill of an open window.
Make sure that you set the frequency of sending data.
Take a test drive with the device. Some trackers do not send coordinates if the unit does not move.
If after that the tracker still doesn’t show online in Wialon, please contact us at hw@s-watcher.com and we will try to assist you.
Wialon doesn’t store raw data from units. Why?
Copied!
Raw data storage requires huge drive space and is not of practical value for users.
My device sends only LBS messages. What’s wrong with it?
Copied!
There could be a few reasons for it: your tracker doesn’t see satellites, GPS module or GPS antenna is not working.
My tracker does not send LBS data. Why?
Copied!
There could be the following reasons for it.
Your device is not able to send LBS data.
Your device has incorrect settings. To get LBS data, a device needs to transmit at least 4 parameters: mcc, mnc, lac, cell ID. Please check your device settings and make sure your device can transmit those parameters.
You haven’t activated message validity filtering. On the Advanced tab of the unit properties, tick the checkbox Message validity filtering, then activate the Allow positioning by cellular base stations function.
From what devices can Wialon receive LBS data?
Copied!
You can find a list of supported devices in the Hardware section of our site.
My device does not support LBS according to the Gurtam website. What should I do?
Copied!
Send a request to hw@s-watcher.com indicating the type of device for considering the issue.
Can I use dash cameras and MDVRs with Wialon?
Copied!
Yes, you can! Wialon supports video hardware which allows for real-time video tracking as well as getting video files from the device’s memory by command or event.
The full list of supported video hardware is available here.
I have a video device which is not in the list of supported. How can I integrate it with Wialon?
Copied!
Video monitoring in terms of GPS tracking is quite a young industry therefore not all video devices are suitable for working with GPS tracking platforms. To integrate a video device with Wialon, it should meet some requirements from our side. If you want to have your device supported in the system, kindly email us at hw@s-watcher.com and we will analyze the possibility of integration.
