User Settings
Users can configure some system operation parameters according to their needs and tasks.
User settings can be changed if the corresponding checkbox has been marked in the user properties dialog.
To view user settings, click on the username in the top panel and then choose User settings in the menu.
The User settings dialog can contain up to five tabs, depending on the system configuration:
The settings of one user can be imported to other users. Here you can learn more about the transfer of user settings.
