List of Services
Here is the full list of services available in Wialon system.
Service | Description |
Admin fields | Allows to create admin fields in the properties of the unit, user or group (on the Custom fields tab); defines the available quantity (in total) and the cost of such fields. |
Advanced reports | Allows to use advanced reports, i.e., reports by unit groups, users, drivers, trailers, as well as groups of drivers and trailers (except for the Log table for users and unit groups). Works within Reports module. |
App for iOS and Android | Activates access to the application for iOS and Android. |
Commands | Activates the corresponding tab in the Unit properties dialog; defines the quantity (total for all units) and cost of commands. |
Create resources | Activates the button to create resources and accounts on the corresponding panel (available only in CMS Manager). |
Create unit groups | Activates the button to create unit groups in the corresponding panel. |
Create units | Activates the button to create units in the corresponding panel. |
Create users | Activates the button to create users in the corresponding panel. |
Custom fields | Activates the corresponding tab in the properties of the unit, user or group; defines cost and quantity (in total) of custom fields; does not affect drivers and trailers. |
Dashboard | Activates the Dashboard page. |
Drivers | Activates the Drivers module and defines cost and quantity of drivers; if disabled, the Drivers panel is not shown, and any mentioning of drivers disappears from notifications, user settings, and SMS dialog. |
Eco driving | Activates Eco Driving tab in the Unit properties dialog, as well as the same-name table in reports. Besides, Eco driving app does not work without this service. |
Еmail notifications | Allows to send notifications by email. The service limit depends on the number of purchased licences. We recommend sending no more than 10 notifications per hour so as not to overload the server. |
Еmail reports | Allows to send reports by email. The service limit depends on the number of purchased licences. We recommend sending no more than 10 reports per hour so as not to overload the server. |
Fleetrun | Activates access to the Fleetrun application. |
Geofences | Activates the Geofences module and defines the cost and quantity of geofences; if disabled, the Geofences panel is not shown, and any mention of geofences disappears from reports and user settings. |
Google (custom) | Allows to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. The service works with the key purchased from Google. With this service used, Google maps do not work in the Logistics application. |
Google (standard) | Allows to regulate access to the Google maps, geocoding, and routing for the lower-level accounts. The service works with the key purchased from Google. It is recommended to use this service and disable the custom one. |
GPRS traffic | Allows to control GPRS traffic through jobs, notifications, reports, and unit properties. |
Groups of drivers | Defines the available quantity and cost of driver groups; works within the Drivers module. |
Groups of geofences | Defines the available quantity and cost of geofence groups; works within the Geofences module. |
Groups of passengers | Defines the quantity and cost of passenger groups; works within the Passengers module. |
Groups of trailers | Defines the available quantity and cost of trailer groups; works within the Trailers module. |
Hecterra | Activates access to the Hecterra application. |
Import/Export | Enables access to the dialogs of import/export in the user menu; activates the Create from WLP button in the Units panel and the Export in file button in the unit properties dialog. |
Jobs | Activates the Jobs panel and defines the available quantity and cost of jobs. |
Locator | Activates the Locator option in the user menu. |
Maintenance | Defines the available quantity and cost of the service intervals; if activated, the Service intervals tab appears in the Unit properties dialog, maintenance can be registered in the Monitoring panel, and the corresponding notifications and reports appear. |
Management system | Access to CMS Manager. |
Messages | Access to the Messages panel. |
MGRS | The service allows to activate the MGRS grid for Gurtam Maps. |
Mobile notifications | Activates the corresponding action in notifications, as well as the tab in the Manage applications dialog (in user menu). |
NimBus | Activates access to the NimBus application. |
Notices to users | Allows to receive notices from the administrator of the service. |
Notifications | Activates the Notifications panel and defines the cost and allowed quantity of notifications. |
Orders | Activates access to the Logistics application and allows to generate corresponding reports either on units or drivers. |
Passengers | Activates the Passengers panel and defines the cost and quantity of passengers. |
Profile | Activates the Profile tab in the Unit properties dialog and the same-name table in the reports. |
Reports | Activates the Reports module and defines the cost and allowed quantity of report templates; if disabled, associated jobs and notifications disappear and the trip detector cannot be used. |
Resources | Activates the Accounts panel in CMS Manager; defines the quantity and cost of resources and accounts. |
Retranslators | Allows to transmit messages from units to other servers and systems; activates the corresponding panel in CMS Manager; defines the allowed quantity and cost of retranslators. |
Route rounds | Allows to create routes and defines the number of allowed rounds and their cost (within the Routes module). |
Route schedules | Allows to create schedules and defines the number of allowed schedules and their cost (within the Routes module). |
Routes | Activates the Routes module — enables the Routes panel and associated reports and notifications. |
SDK | Remote access to the system via SDK and access to Apps. |
Sensors | Activates the corresponding tab and defines the number of sensors (calculated for all units in overall) and their cost. |
Site access | Here you can allow/deny access to different sites within your system (like Wialon Mobile v2, extra sites, etc). |
SMS messages | Activates access to SMS messages. In order to send SMS messages, the Can send SMS option should be activated in the user properties. This service doesn't allow limiting the number of available SMS messages and specifying their cost for a billing plan or account. |
Tachograph | Activates the Driver activity and Infringements tables in reports on drivers. |
Toll roads | Activates the Toll roads mileage and Toll roads cost columns in the Trips report and adds the corresponding statistics fields in the advanced settings of a report template. The service uses the Platon toll system. |
Trailers | Activates the Trailers panel and defines the cost and quantity of trailers. |
Unit deactivation | Allows to view the information about deactivated units. Top-level users and users with dealer rights are also able to deactivate units. |
Unit groups | Defines the cost and quantity of unit groups. |
Units | Activates the corresponding panel and defines the cost and quantity of units. |
Users | Activates the corresponding panel and defines the cost and quantity of users. |
Video | Activates the video surveillance mode. |
Wialon Mobile (2) | Access to Wialon Mobile v2. If mobile service URL is different from m.s-watcher.com, it can be disabled only through the Site access feature. |
Yandex (custom) | Allows to regulate access to Yandex maps for the lower-level accounts. This service works with the key purchased from Yandex. If used, Yandex Maps do not work in the Logistics App. |
Yandex (standard) | Allows to regulate access to Yandex maps for the lower-level accounts. This service works with the key purchased from Yandex. Geocoding, routing, and panorama are available for the service. For geocoding and routing you can set the allowed number of requests. |
Yandex (standard) — geocoding | Activates the geocoding for the Address tool, the Monitoring panel, the Messages panel, and the application Logistics. |
Yandex (standard) — panorama | Activates the viewing of panoramic images of the locality for Yandex Maps. |
Yandex (standard) — routing | Activates the possibility of building routes by Yandex Maps for the Routing tool. |
